Those with Denison Gateway 500 (ipod/iphone as well as aux input?)
Trying to figure out if the Denison Gateway 500 will let me setup the following to a CDR-23.
*An ipod (ipod input)
*A portable in-car sat radio (aux input)
Also, if the Denison doesn't come with it, is all that is needed to use the aux input is a cable with audio rca's on one end and the headphone jack plug on the other?
TIA!
TIA!
Parts Specialist
OK - seemed a bit odd, Had me wondering what song you planned on listening too while whipping a$$ around the track......
OK - I know.....
back in the box - right
OK - I know.....
Newbies Hospitality Director
TIA!
TIA!
Edit: Never mind... just saw that you posted this on the 997 Forum also.
yes, you can have both and switch between the type of input.
I have the aux RCA input, the USB flash drive and the iphone/ipod dock connector.
BUT, I will say that w/ the CDR23, it's probably easier to crack the NSA Encryption code than figuring out what the hell the Dension is doing especially with the flash drive since the UI makes zero sense.
I'm a bit frustrated with it but it's better than nothing.
I'll probably pass on the USB drive and stick to ipod and sat radio. Less complicated the better ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
And, yes Tim, I like to listen to music while I whoop it up on track......coincidence???
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
