Hardtop Size?
I just bought a hardtop but it's 350 miles away. Can someone give me some dimensions of the top? I need to try and get it inside my Suburban if possible. Can't drive the 996 to get it right now.... Thanks... Mark
What dimensions do you want? I can run out to the garage and get you some quick numbers.
From back to front is ~70"
From side to side is ~50"
From top to bottom is ~20"
I am shopping around for a hardtop for my 2004 C4S. Shipping is killing me, but now you mention it may not fit - That's just an added hassle. And $700 for pins is ridiculous!
How did it all work out?
Just did all of this on my 04 C4S last year so i figured i would add some points. After a certain model year, if your car did not come from the factory with the hardtop, your car may NOT even be equipped to accept a hard top. You need to make sure you look under the plastic covers were the pins would go in. If it is a vacant hole then you need to order those parts too. My car had the Hardtop Delete option so it did not come with the hardware to accept the top. I went on ebay and found a salvage yard that sells the parts you will need for $100.00. The parts are extremely easy to install and the salvage yard was nice enough to supply the hardware. My understanding is there is only 2 options for the pin types. One type is a screw that you actually torque it to a spec when installing the top (suppose to be the better/quieter option) and the other is just a pin with 2 tabs that turns and locks. When i was on the hunt i personally found the pin type more commonly found. After buying a used/new top, paint and hardware i was in it for under $1,000
