New spark plugs - why didn't I have this done sooner??
#47
I learned a looong time ago to always use the Manufacturers torque spec after working on way to many cars that others had stripped out.
Another thing that will and can happen if they are not tight enough is they will back out slightly and you will hear what sounds like a bad lifter or quiet rod knock and you will think your life is over. As hard as it is to get to these plugs they should always be tightened to spec.
#48
My wife got me a torque wrench for christmas. I torque everything I can.
She asks me to hang up a painting--I'm torquing those damn framing nails. To what and how I don't know but they're getting torqued.
#49
Is it the consensus here that after 10 years of firing, plugs should work as good as new, as long as they don't exceed the recommended miles?
All I know is my car runs better with the new plugs. Unless removing and installing the coil wires caused a better connection / spark, why else would my car run better after a plug change?
he replaced all six and car ran, and still runs, great. he explained that the porsche is pretty good with the wear intervals on the wear items (such as spark plugs, etc.) and he was not surprised that i had some issues a mere 1k miles after my recommended service interval.
by the by, the plugs were clean and didn't seem dirty or sooty, but the points were worn.
#50
"..but the points were worn.."
About which that nice and solid 40,000 volt spark pulse doesn't give a damn......
"..misfires all over the place..."
And they'll be back....
#52
You will/should love the Fister D mod, because the sound is such an improvement over stock. I did this mod just last month, and I would rank it one of the best improvements you can do on a 911. Darin is informative, and easy to deal with. Good choice IMO.
#53
Thanks!
Rudy
#54
Go to page 4 of postings, first one listed, go to post #14...great diagram of exhaust.
#55
i find it interesting that people seem to stick to their theories even in the face of empirical evidence to the contrary. so unless i run into evidence to change my theory, i would assume that worn points make a difference to spark plug performance.
#56
Newbies Hospitality Director
#58
Failure of spark plugs on a stock engine in less than 50,000 miles is extremely rare and simply because someone changing them earlier and "possibly" getting better peformance afterwards, is no reason to simply start changing them sooner when there is no indication of a problem. Even the cheapest plugs will last 50,000+ miles, thanks to the unleaded fuel we use along with better fuel management.
A lot of other cars can go much longer. But it depends on the car/engine/ignition system/etc.
Your post also doesn't take into account engine run time which is more important than car miles.
These cars break down coil packs pretty frequently too.
b-man
#59
If you want a performance engine to stay performance at its best then check and change as frequintly as possible. There is nothing wrong with pulling plugs to keep an eye on the type of burn the engine is getting. I wont take about the ease of pulling plugs on the 996.....hehehe
#60
Sorry about the late thanks (business travel has a way of interrupting forum addiction), but perfect!
Much appreciated!
Rudy
