Safe highway RPMS
I think when I went on my DE I was in the single digits for fuel economy. What a fun use of hydrocarbons!!!
Yes, I really want to avoid the "fun tax".
I feel much better now that many of you have posted your opinions that cruising in 6th gear shouldn't be a concern. I thought it would seem rather sensless to have to cruise down the highway with the engine roaring just to keep the car from lugging. Otherwise, we might as well put Honda 4 cyl engines in our cars.
i still spend most of my local/city driving in 3rd gear. i cruise around town @45 MPH in 3rd at around 3000 RPM. i definitely avoid lugging the engine :P
Is it a "surge"? A transient increase in Rpms or acceleration? Or is just more like a bit there's a bit extra peppiness that continues?
These engines have a resonance valve in the intake manifold that is manipulated around the 3K rpm point to take advantage of the way the air moves through the intake system.
When this valve is opened, not only does this perk up the engine -- provide a bit of a boost in HP/torque -- the intake sound changes as well.
This is normal.
If you are experiencing a transient increase in rpms or acceleration, that is you are holding the throttle steady or steadily applying more pressure to the throttle and experience a momentary increase in acceleration that is not normal and that is not due to the resonance valve in the intake manifold opening or due to the VarioCam system being activated (at least assuming these are not malfuctioning and changing their state due to some mechanical or electrical malfunction).
Both the VarioCam and intake resonance flap are controlled by the engine controller.
Each has a specific rpm level at which a state is selected. (Other inputs also can affect if a state is selected, for instance coolant or oil temperature.)
Each has a specific rpm level at which the current state is deselected. The separation in rpms is several hundred rpms so unless you are accelerating the car up to and over 3K rpms then releasing the throttle and allowing the car to slow until rpms drop several hundred rpms below the activation rpm level there is something else going on. Probably something not normal, to state the obvious.
Under normal driving conditions, that is if you can manage to hold rpms constant within 200 rpms (or so) a state once entered will not be left again. The rpms must decrease or increase by around 200 rpms in order for a state change to occur.
Sincerely,
Mactser.
This is normal.
Sincerely,
Mactser.
On long drives, I vary my RPMs by going into 4th and 5th periodically on my Tiptronic. I usually like to keep my RPMs about 3000-3500 all the time around town, using the manual mode, IF I kept my car in 5th on a long trip with 24-2800 RPMs, I would wory about lugging the engine. I know when my wife drives the car only in auto mode, afterwards, when I drive it it seems sluggish and takes a few minutes at higher RPMs to clear out the slugglishness. After a business trip, I can always tell when my car has been drivem in auto mode because it doen't have that spark it usually has when I drive it regularily in the manual mode at least 3000RPM or higher.
Now hehehe the advancing and retarding the ignition is the opposite concerning where it puts the power. Advancing ignition sparks early so that by time a faster spinning engine fully ignites the fuel the piston is near top dead center and not sparking late in the combustion cycle. Just remember they are opposite in power dabbling.
My personal opinion? rpms are related to cops saying stop doing that or pointing laser guns on the hwy. Other than that just cruise it and stay away from doctors or they'll have you gulping meds the salesmen recently offered them kickbacks for selling.
He has a 2001. Did the 2001 have a variocam?
IIRC all M96 water cooled engines came with VarioCam, which is variable intake valve timing.
VarioCam Plus came in circa 2004 (?). (My 03 Turbo has it and it appeared on other engines afterwards not before, so I'm guessing the 2004 number.)
VarioCam Plus is intake valve timing with intake valve variable lift control as well.
I have an intake lifter from a VarioCam Plus engine on my office desk. Very cool device.
Sincerely,
Macster.
Sincerely,
Macster.
2400 or so rpms not lugging engine unless you're climbing a steep grade. Even then as long as you don't give engine full throttle but ease it on a bit until rpms climb that is not lugging engine.
Porsche knows as well as anyone can how these cars are driven and has designed the engine and transmission to deliver good torque at lower rpms, though of course then engines do pull well to redline and deliver the goods when asked.
Sincerely,
Macster.
My advise is just drive it. If it has been sitting take it easy on it till the rubber and plastics have sealed back up. Rubber and plastic do a little shrink or expand game at times when lacking normal usage. Just drive it and don't feel bad if you....well.....sort of open it up The cars a killer so don't expect it to fall apart from easy cruising. BUT if you give us time to set up the youtube video cameras we will advise you to stay in top gear using 5-7000rpms. Just give us the route and I'd be glad to hang back behind you videoing
Enjoy the car - if the IMS worries you that much, you should have bought a different car...
Rudy
Sincerely,
Macster.
Sincerely,
Macster.
basically all the 3.6s
per Porsche "VarioCam Plus combines intake-side camshaft control (VarioCam) and intake- side valve lift switchover (Plus). The valve lift control system consists of switchable flat-base tappets on the intake side actuated by an electro hydraulic 3/2-way directional control valve. The intake camshaft provides two different cam profiles with corresponding valve lift curves to act as required by selectively switching the relevant cams. The flat-base tappets have two nested lifters which can be locked together with a pin. The inner lifter is in contact with the small cam and the outer lifter with the large cam. A hydraulic compensation element takes care of any dynamic valve clearance adjustments."
