Window Pecularities
Hi thanks for any advice. Firstly, about a week ago the drivers window started making a very audible rubbing/scratching sound when raising or lowering. There's no mark on the window,but somethings wrong.The other thing started about two days ago.( With the door closed) about 2 seconds after the window reaches the top, it drops about 3-4 inches then stops. To keep the car secure I can edge it almost to the top and it stays there. Don't know if the problems are related. Any ideas?
Cheers,
Jason
Cheers,
Jason
+1 on windows regulator, all the windows on my 2 old bimmers started with this kind of rubbing/screaching noises before the cable will completly cease to move (jammed-up). You could DIY this, not too hard. Check yours before you cannot close your windows in the middle of a rainstorms or at the mall. Good-luck....
