Transmission Main Pinion Bearing
4th Gear
I have a 2000 C4 Cabrio, I take down the tranny because the Main Pinion bearing fails. Reading about the problem I found that the failure is cause because the bearing is sealed and the grease fail due to heat. I am looking for a replacement with out the seal. Any after market replacement?
