996 Forum 1999-2005
Code P0348 - HELP!!
Old Dec 16, 2009 | 08:55 PM
mmasse's Avatar
mmasse
Default Code P0348 - HELP!!
I just finished a clutch/RMS/IMS job and when I turned the engine on the Check Engine Light went on. I checked the code and I get: code P0348 Camshaft Position Sensor "A" Circuit High.
What could be the reason for this?? Can I just reset the light?
Old Dec 17, 2009 | 06:41 PM
Macster's Avatar
Macster
You can try. Clear error codes and extinquish light and see if light stays off. If if does, result!
If not, then ...
You disturbed the camshaft position sensor connection to the wiring harness or damaged the wiring is my WAG.
Time to locate the connector and make sure the connection is good. Sometimes if a connector is disconnected then connected because the connectors are old it takes more force to get a solid connection. You should feel some kind of snap as the connector seats fully home. You need to look very closely at the connector to see if there are any latch that this latch has obtained a nice latched position.
Before you attempt to reconnect the connector though shine a good light into both connectors and very no pins are bent or or broken off. An old connector can suffer this failure when messed with even if one is careful.
While you are there carefully inspect the wiring from the sensor to the connector and the connector to make sure nothing got damaged during the repair work.
Sincerely,
Macster.
Old Dec 31, 2009 | 12:02 AM
1way2rock's Avatar
1way2rock
Default Can you post pictures
I am having the same problem. Please post pictures
Old Dec 31, 2009 | 12:03 PM
Macster's Avatar
Macster
I have no good pics of a 996 engine showing location of the connector. What did you last work on before the P0348 error code showed up?
Sincerely,
Macster.
Old Mar 28, 2010 | 01:48 AM
1way2rock's Avatar
1way2rock
Default found problem
The wire was cut to sensor. The sensor is okay just had to replace wire.
By Michael S. Palmer | 2026-05-22 12:28:55
