Sounds like Marbles, Oil Everywhere
#63
Newbies Hospitality Director
Look at the Option Code sticker located either a) under the hood (trunk) or b) located in the front inside cover of one of his Manuals, most likely the Maintenance Manual. If you find the option code X51 then, yes, he does have the Carrera Power Kit option. If you don't see X51, then he probably does not have that on his car.
The X51 option is the most expensive option Porsche offers and cost $16,900 from the factory. It can be retrofitted later, but is is even more costly to do it after the car is built.
