Gas cap replacement
I had a P0456 check engine light a couple weeks ago.
I replaced the gas tank cap.
The old one had a very brittle, cracked o ring. What abysmal quality from a Porsche?
Left one is the old one. Hard to tell from the crappy cellphone camera shot.
Anyone have hints as to how to reinstall the strap to the car?
I replaced mine and it's very easy, at least for a 2003. Where the tether is anchored to the chassis, there is a plastic pin in the center of the tether base. Push it through w/ a tiny screwdriver (or, what I had, a dental pick) and be careful not to lose the pin (my new gas cap came w/ a new pin).
After the pin is out, just remove the old base/tether/gas cap, install the new base/tether/gas cap, and install the pin to hold the base in place.
///Michael
///Michael
///Michael
///Michael
Np, the tether is anchored to the bottom right - let me know if you need a pic to illustrate.
When you re-install the pin, there will be no positive stop so just push it through until it's flush w/ the base.
Good luck.
///Michael
Good luck.
///Michael
Old post, but that pics help a lot. The clip shold be inserted to the sheet metal, then the tail of the fuel cap inserted below the sheet metal. Otherwise if the clip is inserted to the tail of the fuel cap then to the sheet metal, the fuel flap spring will interfere as the whole works protrudes too much.
Thanks for the pic!
Thanks for the pic!
///Michael
///Michael
