is the 996 considered slow for today?
#61
Ironman 140.6
In fairness that video reflected your skill as a driver more than real difference between the cars. With equal drivers a 996TT should fairly stomp a 996 C2 on any road course.
Crazy stuff like this can and does happen at DE's. I've passed multiple 996TT's in my lightly modded 986 (I even passed a 997 GT3 RS once) at DE's before but I have no illusion that I was driving the faster car, rather I was passing a less experienced driver.
#62
The first step is to address the end that is having the issue. If you are oversteering, you should start by softening the rear bar. If understeering, you should soften the front. [Of course you could do the opposite thing at the other end, but generally you adjust the other end only when you run out of options at the end with the problem]. Same goes for the shocks and springs (soften rear for oversteer, soften front for understeer). Keep in mind that if you have only 1-way adjustable shocks, you can't change bump independent of rebound. All that being said, if you don't have ANY adjustable parts, then you really have no choice but to mess with the tires.
It is commonly touted that 996s understeer, but I honestly can't remember this happening to me at the track when I had my stock setup. You really need to be going close to 9-10/10ths for this to manifest itself anyway. And, if you are understeering a lot, you can try trailing into the corner a bit to rotate the car and also keep some extra weight at the front. Anyway, to take out some understeer, you should stagger the pressures front to rear by lowering the rear or raising the front. But there isn't much room for movement in most tires before you start exceeding optimum temperatures. And not all tires react the way you would think when you change pressures.
I have found that the main reason most people in 911s complain about plowing on entry (severe understeer) is actually due to their braking technique and NOT setup.
Back to the original post - I have taken my 335 out to the track, and it is nowhere close to my old 996. Those 0-60 times mean very little if you can't put the power down coming out of a corner.
-td
#63
Again, as someone mentioned before. It depends on what you are looking for in a car to decide which one fits your needs. Both good cars in there own regard.
OT... This is what you do to get rid of the ****ty Run Flats on the 335.. So yea that torque can be fun
#65
#66
Well, that once was the case, but not so much anymore. A stock 996 6-speed will accellerate a new Mustang GT, a new Camaro SS, and a new Dodge Challenger SRT8 (and the recent Pontiac GTO and G8). They have more engine but they all have far more weight. Looking back to the original premise of the OP, horsepower-to-weight ratios on these cars are actually worse than the 996. And whereas torque gets the show in the road, there is a lot whole lot more show to move on those cars. And, interestingly, they have no more rubber in the rear than a stock 996, and they have no weight over the drive wheels. Tons of magazine write-ups and camparisons to research if you care, but the numbers don't support the current heavy metal pony cars as drag racers, without serious upgrades to the suspensions, and a serious visit to Jenny Craig.
I frequent www.challengerforumz.com and there is constant discussion there about the accelleration comparisons with the other three, and how to get the lead out and the power down on these cars.
#67
man you all are wasting your time, the 996 AND bmw are sandbaggin.
I actually got to drive one of the old 1989 Turbocharged 3.8L V6 Trans am's.
its 0-60 is 4.6 for a 3346 curb weight car! and it was produced 20 years ago!
referance=http://en.wikipedia.org/wiki/Pontiac_Trans_Am#Trans_Am
http://89tta.turbobuicks.net/ttaspecs.htm
ok moderator we can lock and archive this thread now.
#68
