Problem with headlights
When turned on, the low beams look very very dim. However the high beams work fine and the fog lights work as well.
I have tried changing the bulbs and I also changed the headlight switch, but still nothing...
Any other suggestions?
Thanks!
that sounds like a grounding issue - anything corroded inside when you swapped bulbs? check connections...
swap your headlights with known working ones of a friend - if the prblem goes away you have it isolated...where are you located ?
PS welcome to RL and when you get a second post a quick BIO and a couple pics (even just cell phone pics if thats all you have)
Yes, both bulbs are dim. I purchased new bulbs to replace the old ones so I am fairly certain it's not the bulbs. I did not remember seeing any corrosion on the connectors but I will definitely give it another look.
I did have my ignition switch changed not long before this problem came up, I am wondering if that could possibly be related?
