What triggers immobilizer?
I've searched quite a bit here and on renntech.org and I haven't been able to determine what are the criteria that will trigger the immobilizer -- anyone know?
My car will crank with the ignition switch if I jump the relay, but with the relay in place it will not crank. I checked the wiring to the RFID coil and the clutch pedal and both are fine. Any other ideas?
Do you have your manual? There is a section on some of the reasons it will trigger and how to reset it. Reset was something like - Close all doors trunk and engine covers. manually lock and unlock the door with the key get in and start the car before the alarm goes off.
