'Soft' brake pedal issue found...
...the brake booster is kaput. Why: the little area it sits in was full of water - the brake booster ingested water over a period of time and became rusted out. Fix is to replace the brake booster and check valve. ![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Why did the boot area become 'flooded'? Because the drain was clogged. Recommend you all remove the battery cover and that cover over the master cylinder area and check for standing water !!!
Rocky Mountain High
Mine was replaced last year for a similar issue.
