Installed: EvoMS V-Flow and GIAC 93 Octane ECU Upgrade
#31
I would check your seals between throttle body and air flow tube. I've got the same CAI and never get 'searching', maybe a small air leak. A build up of carbon deposite in the butterfly flap could also cause this, get some carb cleaner in there...
Good choice on the CAI though, bit of a pain to change over cone filters but otherwise great product, oh and watch the EVOMS name plate, the screws holding it on have been know to come loose, I took mine off after one screw went 'missing'...
#32
It's to keep the hot air from the engine from getting into where the filter draws its air from.
#33
#34
Quote:
Originally Posted by savannah996
i have looked under my trunk lid to see where the opening to draw air in is for this system. (above the air filter) i see there is a seal around the top of the filter box to seal aginst the trunk lid? but why does it do this?
Pete
#35
Probably because it's a lot cheaper to just put some molding around the top of the box and let it seal against the hood rather than creating a removeable top.
#36
#37
I have also wondered why the filter seals against lid rather than a cover. I can't believe it is just cost (which could just be passed along to us P-car owners anyway). It would be interesting to know why it was designed like this. Perhaps just to make us check the filter every time we check the oil?
#38
From: 996C2,6sp, Fister-d mufflers, K&N CAI, Savannah, GA
ohhhhhhhh its to REPLACE the filter??? me thinks?
I thought it had something to do with another inlet for airflow to the filter. which is why i looked for a air channel in the lid.
maybe one of the ballers with a GT3 (or racing) lid can tell us if there is a hole in the right side, over the cone filter?
#39
