PSE Relay and Speed Sensor
Does anyone have a picture of the PSE relay that is located under the dash and a location/picture of the pink wire that needs to be cut to take out the 35 to 50 mph quiet period? While I currently run teh car with the plug removed in the engine bay, sneaking out for early morning golf rounds require the quiet mode.
It's not a wire, it's a diode that you have to remove from the relay.
Here is the thread on RennTech: http://www.renntech.org/forums/index.php?showtopic=2470
- Anthony
I saw in a prior thread that cutting a pink wire would remove the speed sensor to the relay and remove the all the time quiet speed zone. Too much trouble with teh diode, I will just leave it loud.
