Replacement Battery Information
#32
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
Yes, my new battery came with a hard plastic vent tube that hooked right up to the tube on the car. It is a conventional acid/plates design (I chose not to experiment with Porsches new ultra light weight Lithium-ion battery for the GT3RS and Cayman R - at just over $2400 each...) ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
The purpose of the vent tube is to keep gases and fluids inside the battery from spilling onto the mounting plate and surrounding body/electricals.
If you choose an Optima or similar construction gel-type battery, there is nothing to spill out and those batteries do not have vent tubes. However, they do need a special mounting bracket (not included with the battery) for installation in a 996.
#37
I went with an Interstate H-7. Not lighter, but an exact size replacement fit. Interstate batteries are high quality and I have had very good luck with them. These cars have long battery cables and I did not want a marginal quality battery stressing the electrical system.
#39
So today turned out to be my battery replacement day.
I narrowed the choice down to the Interstate MTP-H7 and the Duralast 94R-DLG.
I chose the Duralast primarily because it was about $30 cheaper.
The 94R-DLG does NOT have a vent drain outlet, but otherwise it is a near match to the OEM Moll battery. The bracket holds it in place firmly and the terminals reached the posts without stretching.
#40
Just purchase and installed a new Interstate MTP-H7 battery for my 2000 911 C2, fit like a glove. Paid $149, searched all around, and on the internet. That was the best price I could find. Prices ranged from $149 - $189 throughout the Detroit-Metro area, for those who had them in stock.
#41
OK I know this is an old thread but I need a battery for my 99 996. The one in the car is OEM and was purchased in 2005, so I believe it has lived a good life. So I called the dealer for a price and they said $200, and I thought why fool around to save 50-75 $ when the last OEM lasted a long time. Then he said plus $100 installation to reset the electronics?
Is this really a $100 installation, in all the threads I've read I saw nothing about resetting anything. If your telling me I have to reset my radio stations, so be it I can do that for free. I went to Autozone their price was $125.99 installed. But the tech had never installed on in a pcar and thought the dealer was just giving me a line. He is correct, just pull out the old one and put in a new one? Do you need the radio code to reset the radio? What am I missing?
#42
For a 99, if you completely remove all current, you would need to reset the radio. But you can plug in a trickle charger while you replace the battery -- or even some of the small cell battery packs into the cigarette lighter to keep current in the system and not have to reset anything.
#43
There are three holes in the battery tray they fit:
H6 (48) MTP-H6 10-15/16 x 6-7/8 x 7-1/5 Top
H7 (94R) MTP-H7 12-3/8 x 6-7/8 x 7-1/5 Top
H8 (49) MTP-H8 13-15/16 x 6-7/8 x 7-1/5 Top
The first 2 holes are threaded, third hole is not. It is close to the edge of the tray and you need to supply your own nut and bolt for the clamp.
I replaced an Interstate MTP-H7 With a Braille 7548 AGM battery direct replacement.
Braille AGM B7548 battery group 48
BCI Group: [?]Group 48
Length:10.9" (277mm)
Width:6.8" (173mm)
Height (without posts):7.5" (191mm)
http://www.braillebattery.com/index....tteries/b7548#
Width:6.8" (173mm)
#44
![rockon](https://rennlist.com/forums/graemlins/rockon.gif)
#45
You certainly have to watch what the dealers do... 5 years ago on my cars PPI I was told the handbrake needed to be replaced because the dash light would not go on. What a rip.
Another trick is to just hook up a donor battery to the main leads using jumper cables (carefully). Then when you remove the battery there is no loss of power.
