996 Forum 1999-2005
Change Oil Level Sensor - DIY?!
Old 07-24-2009, 06:02 PM
frederik_ekelund
3rd Gear
frederik_ekelund's Avatar
Default Change Oil Level Sensor - DIY?!
Hi there,
My oil level sensor on my 996 C2 '01 is faulty and I need it replaced.
Looking at drawings etc it seems to be an fairly easy fix. Have anybody done it? Any instructions?
Many thanks in advance!
Frederik
Old 07-24-2009, 09:51 PM
function12
function12's Avatar
do a search. Someone here just did a nice write up on it . I think it will take a special wrench to get the sensor out. Have you tried just cleaning the contacts. I have heard that works sometimes.
Old 07-26-2009, 09:25 AM
frederik_ekelund
3rd Gear
Will have to continue looking, do you remember where you saw the write up?
Old 07-26-2009, 10:47 AM
ivangene
Parts Specialist
ivangene's Avatar
The write up is for the oil PRESSURE sending unit IIRC
you want oil LEVEL sensor, I have not seen that one written up before (in the last year and a half) -
the part should be 996.606.150 at a cost of about $60... on looking i would guess it to be screwed in and a wire connection of some sort, looks simple -
GL and post pics if you do it.
ALSO - welcome to Rennlist , stick around, follow up on your findings and post some pics or your ride along with a little info about it and or you
Old 07-26-2009, 12:39 PM
function12
function12's Avatar
It was here. Here is the link.
Old 07-26-2009, 12:46 PM
ivangene
Parts Specialist
ivangene's Avatar
thats a great write up on the PRESSURE sending unit - unless the OP said the wong words and meant pressure sending unit, the way I read it was oil LEVEL sensor - a very differant part... that part looks like a long tube that ?screws? into the block and has an electrical connecetion that tells the oils LEVEL - not the running pressure...
I think
Ed
Old 07-28-2009, 05:53 PM
flintworks
flintworks's Avatar
The oil level sending unit is not a fun job. You need to remove half of the intake manifold to get it out because of the length.
Old 07-28-2009, 10:49 PM
ivangene
Parts Specialist
ivangene's Avatar
good to know, that said.... if you have to remove 1/2 the intake you will want to order new o'rings prior to starting (cost me $40 at the local stealership because I needed them "now")
Quick Reply: Change Oil Level Sensor - DIY?!
