996 Forum 1999-2005
O2 sensor removal?
Old Jul 24, 2009 | 07:04 PM
Tippy's Avatar
Tippy
Originally Posted by LVDell
pb blast?
Its like WD-40.
Old Jul 24, 2009 | 07:06 PM
Tippy's Avatar
Tippy
It seems every damn clip in these cars is a new rubics cube every time
Suggestions on proper unclip procedure?
Dell, arent you a Dr.? You can figure it out, I assure you.
Old Jul 24, 2009 | 07:09 PM
LVDell's Avatar
LVDell
Touche'
Problem is that it is finals week and I just wrapped up. My brain is mush trying to get grades done and listen to all the grade adjustment requests. Thanks God tonight is martini night!
Old Jul 24, 2009 | 08:24 PM
gota911's Avatar
gota911
Newbies Hospitality Director
BAWHAHAHAHAHA!!!!
Old Jul 24, 2009 | 08:35 PM
LVDell's Avatar
LVDell
Oh sure, pick on the guy who's brain is in the toilet right now. Real fair
Old Jul 24, 2009 | 09:06 PM
springgeyser's Avatar
springgeyser
pb blast?
PB Blaster is one of the best penetrants I used to loosen stubborn nuts. It is much better than WD-40. I spray it liberally days before I actually work on the car.
Autozone or Kragen, if they have one in your area, will loan out a O2 socket for FREE.
Old Jul 24, 2009 | 09:08 PM
LVDell's Avatar
LVDell
Thanks for the heads up. I'm heading to Autozone in the morning and I'll look for PB Blaster as well.
Old Jul 25, 2009 | 01:07 AM
67FJ45's Avatar
67FJ45
Good point. I'll disconnect the wiring harness and then remove them once off the car.
BTW, what in the world is the O2 removal tool? Dealer thing?
Dell,
If you unclip the O2 sensors and remove the cats, then twist off the sensors, you don't need a slitted socket. An open end wrench should work well.
The electrical fasteners are definitely difficult to remove. I don't know about 986 sensors, but 996 sensors are fastened as follows. The side of the fastener connected to the O2 sensor has two small locking tabs that must be depressed before the fastener can be pulled apart. If your fingers are husky, it could be difficult without using some kind of tool to depress the tabs. I've attached pics here, complete with a Dell background.
Good luck!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jul 25, 2009 | 08:24 AM
LVDell's Avatar
LVDell
Thanks! Just what I was looking for. Maybe I'll try to unclip these suckers first.
Nice play on the "Dell" background!
Old Jul 25, 2009 | 12:14 PM
67FJ45's Avatar
67FJ45
One more bit of info, Dell. There's a sliding retainer that covers the clips. It looks like this on the 996 (see pics). You can pull the entire electrical connector assembly out of the clip that mounts it to the car body (1st 3 pics). Then you just pull the red sliding retainer up, and the connector will come apart easily (4th pic).
I hope my earlier post wasn't too confusing.
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jul 25, 2009 | 12:38 PM
LVDell's Avatar
LVDell
Got it! Had another friend over and was able to describe exactly what you just did. Thanks so much for the help!
Old Jul 25, 2009 | 04:52 PM
himself's Avatar
himself
Forgot I had this link. For others in the future I suppose...
http://mike.focke.googlepages.com/oxygensensors
-td
LVDell's Avatar
LVDell
-td
Beers on you next time!
Old Jul 25, 2009 | 07:15 PM
67FJ45's Avatar
67FJ45
-td
Wow, that's a nice resource. Good link!
By the way, Dell, what are you doing to the exhaust system?
Old Jul 25, 2009 | 07:18 PM
LVDell's Avatar
LVDell
Haven't figured out yet. Have it narrowed to a few different setups. Should have a decision next week sometime.
