996 Forum 1999-2005
Small Leak - What is it?
Old 07-21-2009 | 01:42 AM
spinsall4's Avatar
spinsall4
Default Small Leak - What is it?
Hey folks,
Noticed a very small leak, orangish color, coming from the passenger side rear of the car. I only took a quick look but it appears to be coming from a seal right at the point where a large rubber hose connects. At first I thought it was from the hose clamp but a better look makes me think it is from the metal piece the hose connects to. Super small leak but want to get ahead of it. Very difficult spot to reach as it sits above the exhaust system. Would love some direction here. Car runs fine, no loss of oil pressure, no smoke, idles fine, etc.
Old 07-21-2009 | 01:46 AM
ivangene's Avatar
ivangene
Parts Specialist
Old 07-21-2009 | 01:54 AM
Darren's Avatar
Darren
What year? Has the coolant expansion tank been changed?
Old 07-21-2009 | 02:11 AM
porsche52's Avatar
porsche52
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
Sounds like coolant. Is it the main coolant hose or the smaller 90 deg hose on the bottom of the engine? Regardless it is a very easy fix! Both connections have gaskets that can be replaced. Remove the airbox if it is the upper large hose, it will be right there, easy fix.
Old 07-21-2009 | 02:15 AM
ivangene's Avatar
ivangene
Parts Specialist
passenger side
Old 07-21-2009 | 05:42 AM
spinsall4's Avatar
spinsall4
sorry for the lack of details. Have not had time to take a picture. The car is a 99 cab. Second motor. Its not the small hose at the bottom. Its the big hose that is above the exhaust system. It does look like it is directly below the airbox. Seems like the leak is coming from a gasket of some sort between two metal parts, not the hose itself. Hope that makes sense.
B
Old 07-21-2009 | 08:28 AM
C4CRNA's Avatar
C4CRNA
Is it dripping on the floor of the garage or do you just see some orange stuff in that area?
I'm thinking dried cosmoline.
Quick Reply: Small Leak - What is it?
