996 Forum 1999-2005
Weird Wheel Question
Old Jun 29, 2009 | 03:54 PM
Tommy Carrera's Avatar
Tommy Carrera
Default Weird Wheel Question
Currently I am running 18" 8.5 fronts 10 backs.
Ideally I would like to run 11 wide in back to get some 335/30's on there. What would I run in the front with those rears to help mitigate some of the potential for oversteer?
My thought is to just put the 10"s up front. But I am sure the offset on the Rear wheels is too much to stick up front. (Currently the rims are Carrera III OEM 18")
What fronts came on the 2003-2004 GT2? Those had 11" rears.
TIA
Tom
Old Jun 29, 2009 | 03:56 PM
AFhokie's Avatar
AFhokie
I would totally like to hijack this thread and ask if there is a database somewhere of all the different wheel options that were made availible on the 996.
Old Jun 29, 2009 | 04:22 PM
himself's Avatar
himself
TIA
Tom
Good luck putting 335s on the rear. I have GT3 11" rears and 305 is the most I can get without rubbing. Even with 3 degrees of negative camber. On the front, I can fit 8.5" with 245s, 9" would probably work as well, but more than that and I rub the fender liners when turning.
Also, why are you putting on GT2 wheels? If you search, widebody offsets cause lots of problems on narrowbody cars.
As for oversteer, where are you driving that you get any oversteer? For typical street driving, you shouldn't really encounter it at all - regardless of tires. And, on the track, the car is setup to understeer.
TSB 4440 at Renntech.org
-td
Old Jun 29, 2009 | 04:35 PM
htny's Avatar
htny
335 won't work on that width, widest section will be 315 for an 11.
The GT3 ran 8.5 up front (235 or 245), and 11s out back on (295 or 305)
The GT2 had 8.5 up front and 12s (315) in the back
The widest wheel i've seen fit to a stock regular production 996 of any body style is 8.5 in the front, although technically a 9 would fit at the same offset (since most people have no trouble running a 15mm spacer upfront)
True widebodies (not stock but racecars) like the GT3 SuperCup and RSR can run up to 11 inches up front and 14 or 15 in the back, but these cars are very different from our cars, both at the suspension/hubs and with different fender layouts and widths. Without different fenders you can't do that, nor would you want to on the street.
Best,
Hans
Old Jun 29, 2009 | 04:41 PM
LVDell's Avatar
LVDell
The main to question to ask is why in the world would you want to even try to run 335's? Heavy *** tire, heavier wheel than 10 or 11, slower car.
Old Jun 29, 2009 | 05:18 PM
Tommy Carrera
Default Oo0ps
Ok ok...the 335's were a typo.
305's is what I intended to type.
And as for them being heavy, I am only carrying them 1/4 mile.
Old Jun 29, 2009 | 05:27 PM
LVDell's Avatar
LVDell
Old Jun 29, 2009 | 05:30 PM
SMR996's Avatar
SMR996
WTF?
Old Jun 29, 2009 | 07:01 PM
htny's Avatar
htny
if they are only going to be for 1/4s, you might be best off with straight 8s up front, less rolling resistance on the wheels which aren't driven! For 1/4 mile times, you need to look at a dedicated setup out back, light wheels, probably 17s, DOT slicks or straight slicks, and analyze your shift points before selecting tires. You may wind up being able to eliminate a shift or get into a better part of the powerband by running a shorter or taller RD. Slicks on a 10 inch wheel running low pressure will hook up better than street tires on any width wheel.
Since I know you can't be looking for JUST 1/4 mile times, and assuming the car will make a few turns here and there!: Run 8 or 8.5 up front and 11 out back on the street, any section width you want, you'll be a happy man. The GT3 wheels are a perfect fit. Run 295s or 305s, either will work. Then take your current wheels and buy some hoosiers for the strip!
Good luck and have fun with it!
Old Jun 29, 2009 | 07:38 PM
himself's Avatar
himself
WTF?
1/4 mile = drag strip. I'm sure you knew that
FWIW, there is a thread somewhere on taking a 996 to the drag strip.
-td
Old Jun 29, 2009 | 11:09 PM
AudiOn19s's Avatar
AudiOn19s
To keep the conversation on point...
I run 8.5' fronts with 255 tires and 15mm spacers with no rubbing at 2.5-3.0 degrees of negative camber in the front.
9' and 265's or 275's fit up there but not on my setup as my coilovers have barrel shaped springs and not straight round springs like a GT3.
I think you'll find that most "regular" 996 guys tend to like a 40mm tire width split front to rear. 245/285 is very popular with people on the stock wheels. Cars with more power (GT3 and GT2) fair a bit better with more rear tire to help out with the additional power on tap. If you're going to run 305 rears on a C2 I'd suggest a 265 or 255 front tire based on my own personal experiences.
Andy
Old Jun 29, 2009 | 11:38 PM
Tommy Carrera
The GT3 wheels are a great idea. Readily available and wouldn't have to worry about offsets.
Never noticed the front/back split was usually 40mm. But that is what I am running now in Sumotomo HRZ3's.
Yeah the trip to the drag strip has me thinking about this. I should probably look at buying a used Crown Vic patrol car and dragging it.
The wife is starting to growl about all this drag strip talk. Might have to be a winter project.
And Dell....you are so funny when you are annoyed.
Old Jun 30, 2009 | 06:03 PM
redridge's Avatar
redridge
good to have Dell back on the boards...
Old Jun 30, 2009 | 06:09 PM
LVDell's Avatar
LVDell
Not annoyed as much as confused
Not really back F/T like I used to but drop in from time to time to keep the 996 guys in line. Overall, a great group of guys
...now where's that drag strip sub-forum?
Old Jun 30, 2009 | 11:29 PM
67FJ45's Avatar
67FJ45
Andy
Andy,
Interesting spacer size. You didn't mention what offset your wheels have.
