New Tires, Springs, Shocks, Alignment settings - report w/pics
I ran a 2002 C2 for 2 years in the stock class, I had -1 camber up front and 0 toe. at the back I had -1.5 camber and everything else stock.. that setup worked very well for me.. I laso rand the Sumis III and found that they didnt like high temps, for autox I had 40psi at the fronts and 45 at the backs.. Hope it helps..
Parts Specialist
wpw thanks... it was hot when I ran them and the morning they were much better... 40/45 !!! WOW I think I would have a drift mobile with them that high!!
I will try higher...I can always let air out... hard to put it back in
Thanks for the replies, I will check the numbers,
the toe is in (mm) not degrees - I will ask for a conversion, this is helpful!!
How many miles have you put on the new Sumis? Just read in the Tire Rack that it takes about 500 miles to wear off the lubricant used to release the tire from the mold.
Parts Specialist
~ 100 then (200 now)
I did want to have them on the ground longer before taking them out, but the alignment shop was booked up and the car sat for 5 days
well maybe they will come around....
