996 Forum 1999-2005
Sequential Shifter System
Old Jun 10, 2009 | 07:58 PM
cone crusher's Avatar
cone crusher
Cruisin'
Default Sequential Shifter System
I recently saw this product demonstrated at GMG and was looking for more info and found this forum . Has anyone any experience with such a system or some thoughts ? Seeing that GMG is involved it I feel there must be something good going on. I am going to post this in the 997 forum as well as perhaps someone over there has some input.
Karl
http://www.youtube.com/watch?v=L0soCwlsrfY
Old Jun 10, 2009 | 08:58 PM
LVDell's Avatar
LVDell
Looks like it's only for 996/997 GT2/3/TT
Also, seems to be about 7K plus shifter and install?
Old Jun 10, 2009 | 09:42 PM
ltc's Avatar
ltc
Super Moderator
Needs More Cowbell
http://www.advantec.de/presse/seqshift_e.pdf
Old Jun 10, 2009 | 10:02 PM
htny's Avatar
htny
Sequential but retains clutch pedal right?
So to shift, clutch in, hit paddle / bump stick, clutch out?
If that's the case, how much faster is the gear change really? Still limited by how aggressively you want to shift I would think.
Old Jun 10, 2009 | 10:24 PM
CWay27's Avatar
CWay27
It looks like the M7 system uses the paddles or shifter stick to pre-select the gear you wanna be in and then press the clutch to initiate the shift. You really notice it near the end of the video, especially when he downshifts 3 gears at once.
Old Jun 10, 2009 | 10:40 PM
cone crusher
Cruisin'
That was the way it was explained to me . I think that pre selecting arrangment is called " stacking " .
Karl
Old Jun 11, 2009 | 12:59 AM
russo's Avatar
russo
What is really funny is when he compares the sequential to the manual and states that you don't have to worry about getting blisters on your hand. What kind of manual cars, or better yet, how do you get a blister on your hand from manually shifting gears?
Old Jun 18, 2009 | 12:26 AM
cone crusher
Cruisin'
I think he was referring to blisters that some drivers get after races but that is in a regular sequential shifter car where you have to use force to move the lever . I've driven those and it can be a chore . From what I see in the video the shifter in this case is merely a switch , not a mechanical lever .
Karl
