Oil pressure sender unit replacement - DIY
#92
Oil pressure sensor from the top
Thanks! However my torque tool was too big to use since I did it from the top using a Harbor Freight $8 19mm crowfoot tool and a 6" extension and took less than 15 minutes. I went by feel and works great without leak. It felt like a Porsche colonoscopy exam.LOL Price on these sensors have gone up from $50 to $75-$118. I purchased a Porsche 928 oil sensor for $25 back in 2003.
kupson (03-14-2024)
#93
And find yourself a new Indy mechanic. It's not rocket science, which might be why not to many rocket scientists switch career paths to automotive mechanics.
#94
Thanks for posting this thread with pictures. This thread saved me a bunch of money.
My oil pressure sensor has been acting up...pressure periodically drops to zero, then comes back up.
I just ordered a replacement and will get it installed next week.
#95
5th Gear
As previously mentioned try using low grit sand paper on the connector and thoroughly clean the connectors with alcohol following the sanding. Then paste a small amount of dialectric grease on both connectors. I did this and worked a charm. It took maybe five minutes.
#96
Repair Completed
Symptoms were erratic pressure readings that were able to be reset by turning the ignition off and on. Temperatures were steady and no idiot light so it lead me to believe it was a reading fault.
With a little help from this site and from the linked YouTube. https://youtu.be/KTEm9c5ANEc
The YouTube instructions on grinding down the crows foot helped immensely as it's a tight fit. Also, I followed the instructions from Rennlist to remove the rear right tire and heat shield. Total work time :20
#98
Tried that at first with mine. Light sandpaper, alcohol and electro conductive silicon. No luck on mine.
#99
I got around to replacing the sender yesterday. Cleaning the electrodes on the old unit didn't work. The job to replace the sender wasn't too bad. The recommended claw foot wrench was very helpful. New one hooked up fine and works well.
#101
Quick addition, I just completed this job today and it was a breeze. By the way, it was very easy to get it off from the top side, and on (although the bottom was easier). I used a 19mm Crow socket attached to a swivel, and several long extensions (for the top, only one for the bottom).
Also, you don't have to remove the rear wheel at all, although removing the heat shield (2 10mm bolts) made the job so simple a cave man could do it, lol.
PS for those of you who might do what I did, learn from my mistakes. You don't have to unscrew the top leads for the sensor, they just pull off. (I unscrewed one, and on the installation after cleaning broken it clean off). Ordered one from Pelican Parts, order was simple, shipping was fast, and installation took all of 15 minutes the first time.
#103
