Oil pressure sender unit replacement - DIY
#76
I'm glad I found this thread because it saved me some time and a few bucks. I am doing the 996 cluster conversion on my Boxster and according to Pelican's tech article, the sending unit requires a 24mm crowfoot wrench to install. I was just about to order one when I read this article and now see that it is a 19mm wrench, which I have.
#77
On the same subject...I noticed on some freeway on/off ramps that the needle bounces around a bit even at steady RPM
Could it be an indication of a failing pressure unit when the pressure fluctuates while cornering?
#78
Just chiming in...
I sourced the replacement unit at a local SF Bay area dealer for $67. Prices ranged from there up to $104, all from dealers. I was happy to buy locally, especially at that price.
I found that I only needed a 19mm crowfoot (got a whole set at Harbor Freight for $10), and 3-inch extension, and I did it from the top, with just the engine lid open...no jacking of car, no wheel removal. It popped loose and then I was able to unscrew it by hand. Replacement screwed on easily, then tightened with aforementioned wrench setup. 10 minutes? Maybe 12. Took time to get a flashlight to assist, but otherwise, REALLY straightforward.
Thanks for the help here, folks.
#79
Basic Sponsor
Tron- Thank you for pointing this out. We have corrected the tool size which will be reflected within the tech article as of tomorrow morning.
Thanks again! Mark/Pelican Parts
Your Trusted Source For DIY and Parts
FREE SHIPPING over $99 click here
Porsche Parts | DIY Tech Articles | Facebook | Twitter | Instagram | YouTube | Promos
888.280.7799 | 6am - 5pm PST
#82
Another DIY down
I had the heart-stopping (Oil Failure) message this morning. My Oil pressure gauge has been jumping for a while but now it was 0, then 5, then 0 then 5.
Picked up a replacement at the local dealer(cheapest I could find incl online)
Followed the instructions for working from below. I have a PSE and the only thing I could think of that is in the way of being able to deal with the send from above in part of the vacuum system(or so I think)
It took a little less than an hour including assembling equipment, jacking up, switching units, lowering the car and putting everything away.
Test drive produced nicely functioning sender(no leaks at this point)
What a nice satisfying job.
#84
Not sure about a torque figure but it's only a small fine thread so my intuition says not much torque. Enough to squash the alloy washer a little to ensure it seals. Also tricky to get a torque wrench anywhere near it.
#86
Chandler!
My indy mechanic is telling me it's going to take 3.5 hours to replace... I told him to hold off as I think this is a 1 hour job... looks like I was correct.
I should probably just buy that tool and do it myself.
#88
Torque setting on oil pressure sensor?
Does anyone know the torque setting on the oil pressure sensor? I've combed the internet and found from 15Nm up to 30ft lbs. I know it shouldn't be too tight. I appreciate your suggestions.
#89
I would not hang on the wrench for this as it's a relatively fine thread into alloy so like 25 ft.lbs and start by hand. I only used a 3/8 square wrench to do mine and just tightened it until it felt like the alloy washer was nicely seated. It never leaked.
#90
Torque settings.
http://www.torkspec.com/torkspecme.aspx
