X-51 dyno graph...for no particular reason.
Well I finally got some time to post an introductory pic. I seem to be photo-challenged and don't have any really good pictures so I thought you might like the dyno graph instead. The dyno was done in December of 2008.
Car is a stock 2004 40th Anniversary edition. The engine suffered catastrophic failure in April and was replaced with a fresh crate engine. I might put the car back on the dyno once the new engine has some miles on it as a comparison.
Also, A big thank you to electriclizard for listening to my whine and advising me during the engine replacement.
Obligatory pic..
Obligatory pic..
Here is a picture of the revised "updated" factory IMS bearing. The larger nut is the tip off.
These are rear wheel power evaluations.. That means a 15-20% loss of power through the drive train is normal.
Jack, glad to see you got this taken care of...
Actually, I was quite pleased with the 302hp number. Most stock 3.6l M96 engines dyno around 280hp. So the 302 number for a 3.6l X-51 should be fairly accurate.
As Jake stated the numbers shown are rear wheel horspower. Manufacturers numbers are measured at the crank. The 15-20% loss is through the transmission and driveline.
Enjoy your 40th...very underrated car IMO.
Every dyno is a tad different, but variables like tire pressures, strap tension, the last time the rollers were greased and rear camber and toe will also impact the results.
The Dyno jet is the most repeatable dyno by far.. They have the least variance between units of all makes and thats why I bought one... The way the dyno jet samples is simply speed Vs time, so it really can't be wrong..
These variables in the two X51s here are very close.. The temperature of the gear oil could make that difference in the two evaluations... As a developer my biggest challenge is killing variables that impact results, thats why the majority of my internal engine development is measured in one of our engine test cells, to remove the variables associated with the vehicle... even worn CV joints, brake drag and differential selections can impact the numbers at the wheels..
