996 Forum 1999-2005
Advice on battery drain situation
Old 06-03-2009 | 12:48 AM
Ahsai's Avatar
Ahsai
If your fully charged battery (should be ~12.8V fully charged) drops to 12.3V quickly with 0.17A draw, then most likely your battery is on its last leg. You could disconnect the battery from the car and let it sit for a day or two and see how much the voltage drops. It should be no where near 12.3V.
Quick Reply: Advice on battery drain situation
