996 Forum 1999-2005
Accessing inner rockers
Old May 31, 2009 | 06:25 PM
Staylo's Avatar
Staylo
Default Accessing inner rockers
Good Afternoon,
I'm wondering if anyone has expereinced this issue before and can lend some tips. I'm much more familiar with the air cooled cars.
For some time I have been chasing a rattle in the rear of my 2002 c2 cab.
I have narrowed the location to discover that there is a fair amount of debris inside my drivers side rocker panel. I have accessed through all of the drain holes underneath and from inside of the wheel wells, but cannot get far enough to the center of the panel to get everything. Does anyone know if you can access this area by removing the switch panel on the threshold, and how exactly is this done?
Thanks in advance for any advice. Obligatory pic attached....
Scott
[IMG][/IMG]
Old May 31, 2009 | 07:39 PM
redridge's Avatar
redridge
there should be screws under the side of the car and plastic expansion rivits at the front and rear of the side skirts... the top is held on by 3m sticky tape... maybe if you unscrew the screws on the bottom and one of the rivits, whatever is inside may fall out.
edit: never mind, I just noticed you dont have side skirts...
Old Jun 1, 2009 | 10:21 AM
BillJ's Avatar
BillJ
i have no meaningful content - but your stablemates are both gorgeous.
