996 Forum 1999-2005
Big Puffy Cloud of Smoke
Old 05-14-2009, 10:04 AM
HPTJI
2nd Gear
HPTJI's Avatar
Default Sounds like the oil seperator
Replaced mine in my 99 996 around 35K miles
Old 05-14-2009, 10:20 AM
BillJ
BillJ's Avatar
Originally Posted by MechanicalEng
Just FYI is you decide to replace the AOS dont get the stock one ($95) get the motorsports one, its a 2 chamber Sport oil separator. (p/n 996 107 926 00) List price: $518
This part looks like the stock oil separator, except it is 3x bigger and has 2 chambers that allows oil to be more completely ‘separated’ from the vent tube fumes.
Good luck
Well it is a little late for that as the stock style one will be delivered today. $518 seems a little stiff at the moment anyway. What exactly goes bad on these things?
Old 05-14-2009, 10:31 AM
redridge
redridge's Avatar
I dont think you need a motorsport OAS unless you are pulling serious G's at the track.... the internals of the stock AOS has a tendency to fail over time... the diaphragm deteriorates.
Old 05-14-2009, 10:36 AM
BillJ
BillJ's Avatar
Well I do reach the limits of street tires pretty much right away having done DE's and racing for about 17 years. I usually just tone it back a bit to keep my daily driver shiny side up Next event is Road Atlanta 4th of July weekend. Three days!!!
Do like to keep ahead of all maintenance and prefer to replace prior to failure if indicators are smacking me in the face. 996 has never left me stranded yet.
Old 05-14-2009, 10:47 AM
jumper5836
jumper5836's Avatar
Good luck
Thanks for the info. I think I'll do this when I get my clutch done next year.
I've always had the puff of smoke after driving it hard. I find that if I let it idle for 5-10 min after a DE session that it doesn't smoke but if I just turn off the car it will always smoke up.
My mechanic said unless it is always smoking even at idle then there isn't a problem.
Old 05-14-2009, 11:02 AM
Patrick E
Patrick E's Avatar
Good luck
I looked into this recently, since my car puffs quite a bit at the track. I actually bought the part. However, this is a lot more involved than a bolt-in replacement. After consultation with my indy (who had a lot of experience with cup cars and racing 996's), I decided not to do it since the level of fabrication would be too costly.
Before purchasing this part, I tried to find a 996 owner who actually had done this mod. While several people recommended it, I couldn't find anyone who had actually done it. I did speak with a Cayman S owner who had completed the mod and confirmed that it was quite involved but had the desired effect at the track.
Old 05-14-2009, 11:12 AM
BillJ
BillJ's Avatar
I will try to document fully the work when i do it as well with pictures. Looking forward to tackling it.
Old 05-14-2009, 11:22 AM
MechanicalEng
MechanicalEng's Avatar
I never got the part either, you do have to modify some things to make it fit properly. I decided to solve the issue by selling the C2 and getting a TT, no more AOS issues to report so far
Old 05-14-2009, 11:45 AM
ivangene
Parts Specialist
ivangene's Avatar
which side are you going in from (tranny or airbox?)
I did mine from the airbox side... not bad, a friend did his from the tranny side. Seemed easier - if you go from the airbox side order a set of intake gaskets.... you dont want to re-use those in my opinion and the local dealer will hit you up for ~$40 if you walk in the door.... also might want to get one of those hole clamp spring tools from sears, (~$30 IIRC) and that will make putting those damn hoses back on possible (I replaced mine as there was just no way I could get the stock ones back on)
GL
Old 05-14-2009, 12:31 PM
BillJ
BillJ's Avatar
Did not know there were multiple approaches. Was going to review the manual (porsche service CD) to see what they suggested, but are there some decent links that show the two variations?
Old 05-14-2009, 12:35 PM
BillJ
BillJ's Avatar
Oh and seeing as I have hit upon someone who has actually done it, what hoses should i get?
Old 05-14-2009, 01:03 PM
Patrick E
Patrick E's Avatar
Have you checked Renntech.org? I think they have a good DIY for this.
Old 05-14-2009, 01:31 PM
AOW162435
Seared
AOW162435's Avatar
Originally Posted by StephenB
My air cooled 911 would puff every once in a while.
The car used no oil between 5k mile changes over a 6 year period.
Of course it used oil - what do you think the smoke came from?
Andreas
Old 05-14-2009, 02:13 PM
redridge
redridge's Avatar
hoses?.... I think he is talking about the rubber bellows that attaches the aos and crank vent together... they use spring clamps and is a b!tch to put back on w/o the right tool. Sears sells them....
BTW... from what I understand... you cant buy the motorsport AOS from a dealer... you have to talk to a race shop (for Grand Am).
Old 05-14-2009, 03:14 PM
BillJ
BillJ's Avatar
Yeah i already own those. I thought there was some mention of that in one of the DIY articles that I saw....
BTW... from what I understand... you cant buy the motorsport AOS from a dealer... you have to talk to a race shop (for Grand Am).....
I know a few of those guys actually
Quick Reply: Big Puffy Cloud of Smoke
