996 Forum 1999-2005
Airbag warning light
Old May 11, 2009 | 01:14 PM
aron in toronto's Avatar
aron in toronto
Originally Posted by ivangene
someone post a part number, price and DIY link for the repair
PLEASE
Loren has good DIY info on his site, but here are the part #s I have
Seat Belt Repair Kit #000 043 204 32
included in kit are parts #996 803 183 10 Passenger side buckle
#996 803 183 09 Drivers side buckle
#000.043.204.31 wiring harness x2, looks like an updated ground (brown) wire with heat shrink connector covers.
This kit may have been superseded by a later kit, as this one has been sitting on shelf for a couple of years.
Old May 11, 2009 | 01:20 PM
Last Car's Avatar
Last Car
Originally Posted by Loren
Not true.
If the air bag light is on then there will be fault code(s) that point to exactly where the fault is. If the seat belt buckle (and grounds) update has not been done then this might be a good time to do it.
So, when the light comes on (fault being belt ground) air bags will NOT work.......after clearing fault the light goes out and now the air bags WILL work?
Old May 11, 2009 | 05:08 PM
LJpete's Avatar
LJpete
+1 on the changing out the receptacles. It's not that hard, just takes some time to fish the wiring out of the seat and string up the new one. Other than that, it's not a bad DIY.
I had to swap receptacles from my old stock seats to the Sports that I bought and it was pretty easy.
Old May 11, 2009 | 06:35 PM
chsu74's Avatar
chsu74
Originally Posted by racesx
Correct, was in a hurry to get them in and didn't follow "standard operating procedure" and disconnect the battery, my bad. I'll try getting the light re-set, thanks!
You will need a durametric to shut the airbag light off.
Old May 12, 2009 | 03:07 AM
JDSStudios's Avatar
JDSStudios
No no no!!
Even with the airbag light on, air bag will deploy.
Loren meant you should still repair the problem.
Old May 13, 2009 | 11:14 AM
Last Car's Avatar
Last Car
Okay then, I understand. Thanks for clearing it up for me.
C'ya,
Old Aug 25, 2014 | 05:29 AM
geoffreyaugusto's Avatar
geoffreyaugusto
Cruisin'
I spilled an ice coffee all over the passenger floor of my 02 c4s and the light went on for a few seconds and then turned off. I'm hoping that this isn't the start of a chain of unfortunate events
