996 Forum 1999-2005
Clutch pedal
Old Apr 28, 2009 | 02:30 PM
Riad's Avatar
Riad
Chandler!
Default Clutch pedal
Hi folks,
I just had my clutch, throw out bearing, pressure plate and fly wheel replaced. However, my clutch pedal is really high and much stiffer than I would expect.
Could this be a problem with the master cylinder or something else?
Thanks!
Rob
Old Apr 28, 2009 | 09:42 PM
99firehawk's Avatar
99firehawk
the pedal is high?
The engagment is high? Or the pedal itself.
If the pedal is hard you may need to replace your boost spring.
Old Apr 28, 2009 | 09:46 PM
Riad's Avatar
Riad
Chandler!
I think the pedal is riding high.... and it's harder to engage than normal.
Old Apr 28, 2009 | 09:55 PM
99firehawk's Avatar
99firehawk
I would take a look at the boost spring, lay on your back under the drivers side, depress the clutch pedal with your right hand hold a flash light with the left you will see a small cylinder (1.5 inch by inch rigth above you attached thethe clutch pedal assy, You should see a blue sping, at this point use your left hand to touch the spring, you can tell when they are broken.
Old Apr 28, 2009 | 10:03 PM
C4CRNA's Avatar
C4CRNA
Do not do this if you are over 50!!You will not be able to get out of the car.
Old Apr 28, 2009 | 10:06 PM
Jon996's Avatar
Jon996
FYI, when my clutch was redone this year the pedal seemed a little higher (actually reset the seat a touch to compensate) but the action was not stiffer.
Old Apr 28, 2009 | 10:07 PM
Tippy's Avatar
Tippy
Hey Rob, there are plenty who would offer you their spring.
Old Apr 28, 2009 | 10:42 PM
Riad's Avatar
Riad
Chandler!
Thanks guys! I'll check the spring tomorrow and post back.
Old Apr 28, 2009 | 10:52 PM
1999Porsche911's Avatar
1999Porsche911
It is unlikely to be the spring since it was not touched. It also has no effect on how high the pedal is or the point of clutch engagement.
Old Apr 29, 2009 | 12:17 AM
Eharrison's Avatar
Eharrison
I would bet that the stiffer pressure plate is just confusing your regular "feel" of the clutch and the older boost spring. Similar to how you know when you go into a room but can't remember what you went in for? Same ****.
It's also how dogs feel all the time.
Being higher? I don't know about that part.
Old Apr 29, 2009 | 02:47 AM
ArneeA's Avatar
ArneeA
Being high makes you forget which room you went into and why...... right?
Old Apr 29, 2009 | 03:41 AM
JReid's Avatar
JReid
I'm sorry, but I found this comment hilarious! Though I doubt I will be laughing as hard 20+ years down the line if I find myself in that position under the dash. Glad you made it out.
Old Apr 29, 2009 | 09:16 AM
gota911's Avatar
gota911
Newbies Hospitality Director
Oh crap, another young 'un!
Old Apr 29, 2009 | 10:20 AM
redridge's Avatar
redridge
I would suggest to stop wearing those platform shoes.... it is also very hard to heal and toe with those.
Old Apr 29, 2009 | 10:59 AM
Jon996's Avatar
Jon996
But they are great for improving your heal-and-toe technique!
