Oil Extractor
Over on the 993 board, there is a thread on using an oil extractor. My brother is using one on his BMW and told me that that is what hte dealers use. In the 993 thread, it says that the MB dealers use it too.
Anyone using one on a 996? It would seem to make collection a whole lot easier. Any reason not to use it?
They seem pretty neat and clean to use, but I don't know if they will effectively extract all the oil from the bottom of the sump, that's where all the heavy stuff settle.
My opinion, changing the oil in the Porsche is so easy, both drain plug and filter are so easily accessible, and since you still have to get under the car to remove the oil filter, why not just remove the drain plug as well? I would also think that oil drains faster thru' the drain plug then it does being sucked out of the extractor.
I mean, unless it saves you the trouble of getting under the car completely, then Yes, I might go for it. I can see the oil extractor being useful for vehicles where the drain plug is hard to access. But normally, the drain plug is not an issue, it's the oil filter that's a pain in some vehicles, like in my F150.
Yeah this is true, but I dont think most people use them. Maybe dealers do. The problem is exactly as Cosmos posted in that they dont get all the crud up from the bottom
Location: Where the Smokies meet the Blue Ridge mountains
