Oil Pan Skid Plate Bolt Specs?
Does anyone have handy the specs for the small bolts used to secure the oil pan skid plate?
996 107 981 00
![](http://e-partssales.com/Merchant2/graphics/00000001/D996oilpan.jpg)
I know Suncoast says "Connects to the engine block with three factory mounting locations, no modifications or hardware is necessary.", but I've seen it mounted with small screws.
996 107 981 00
I just put mine on. You use the 3 existing 10MM bolts that attach the hose clamps to each side and the front of the engine. The rear hole is not used. You have no other choice, there is no other way to connect that pan.
