Track doods - brake cooling mod (pics)
#46
Thanks for letting us know!
#47
Come to think of it, has anyone reading this thread done this? With the original wheel well liners? Or ... ? On a 996.1 or 996.2?
And the other big question: Some say venting air into the wheel wells reduces drag and lift, at least that's been claimed of adding vent holes in the wheel well liner similar to those in a Turbo. Has anyone who has done it as shown here noticed any effect on lift or drag?
Thanks again!!
Thanks again!!
#48
RS10 - You need to modify the radiator cowls that side behind the wheel arch liners to realize any benefit.
The cowl collects air that has passed through the rads and then directs in 90 degrees downwards to under the car.
Some say this causes air stacking through the rads and front end lift, I would agree.
You need to cut/modify the rad cowl so as some air can pass straight through onto the back of the wheel arch liner, you then vent, slot, cut the wheel arch liner so as the air passes straight through into the wheel well.
Porsche obviously realized that the 996 design was flawed, as all future model (Including 996 turbo) ducted the air straight through into the wheel well, these models have wheel arch liners with vents manufactured in them, however they will not fit a 996.
I have pictures of mine if required.
Cheers
Cheers
#49
Cheers
Cheers
