996 Forum 1999-2005
Aaarg!! Wierd behaviour and then Cel !!
Old 03-29-2009, 10:46 PM
JDSStudios
JDSStudios's Avatar
Default Aaarg!! Wierd behaviour and then Cel !!
Here we go- my first Cel.
1 Started the car, and it accelerated, all by itself, two quick times,
up to 2500 RPM or so, - never saw that before!! Never heard of it either!
2. Backed off slowly from the garage, as always.
3. Put in first gear and noticed accelerator does not work! press a few times,
no response at all. I noticed idling varying up and down slightly!
4. Because I was already rolling forward in first gear, I stepped on the
accelerator a little harder- it chocked over and over, (as if I was stalling
by letting the clutch go too fast- not the case)
5. Shut down car, and restart- same behaviour!!
6. Drive very slow (still no accelerator) back to garage and shut off engine.
7. Restart engine, and Cel comes on steady. Shut down engine.
I looked around, and all liquids look fine, no leaks.
My evening drive is now cancelled!
Wondering if to take it to Dealer or Indy in the morning.
S#*%*t!!
Old 03-29-2009, 11:07 PM
gota911
Newbies Hospitality Director
gota911's Avatar
JD, sorry to hear that.
When was the last time your cleaned your throttle body? It could be your MAF has gone bad or needs cleaning. It is hard to know what the cause is without reading the cell. If you have a good Indy, take it to him.
Old 03-29-2009, 11:14 PM
JDSStudios
JDSStudios's Avatar
Thanks for replying Tim.
I hope it is what you are saying; I just never heard of a 996 blipping the throttle
2 times all by itself, right after I let the Key go, and then no accelerator at all !!!
PS I have OEM air intake.
Old 03-29-2009, 11:16 PM
JDSStudios
JDSStudios's Avatar
Thing is, without a non responsive accelerator, I can't drive the car to any garage.
EDIT: Could any blown fuse cause this??
Old 03-29-2009, 11:26 PM
gota911
gota911's Avatar
It is possible about the fuse, but I doubt that is the cause. It could be that your fuel pump is kaput. But again, until you get the CEL code read, it is just a stab in the dark. Do you know anyone who has a Durametric code reader?
Old 03-29-2009, 11:36 PM
JDSStudios
JDSStudios's Avatar
Maybe in the Canada section... I was avoiding cross-posting.
It is also weird that the Cel did not come on until the 3rd restart,
yet the faulty behaviour was going on.
Old 03-29-2009, 11:43 PM
Ahsai
Ahsai's Avatar
Is your car e-gas? If not, have you checked the throttle cable?
Old 03-29-2009, 11:45 PM
chsu74
chsu74's Avatar
What are your CEL codes? Bummer about your car..
Old 03-30-2009, 01:29 AM
JDSStudios
JDSStudios's Avatar
I believe it is Egas.
There are other things going on to be just the accelerator- unsteady iddling,
2 accelerations when you first start the engine, and Cel.
This sucks.
Old 03-30-2009, 01:30 AM
JDSStudios
JDSStudios's Avatar
I will try to find out in the morning.
Thanks for posting.
Old 03-30-2009, 01:43 AM
Tippy
Tippy's Avatar
Sounds like the engine is receiving too much unmetered air and then, what you think is a non-responsive throttle is simply the motor inhaling too much air to rev properly.
Sounds like a major vacuum leak.
I would look all around the intake and throttle body for something loose or not connected at all.
Old 03-30-2009, 02:32 AM
redridge
redridge's Avatar
+1, false air reading... or maf needs some cleaning or replacing.
Old 03-30-2009, 02:34 AM
JDSStudios
JDSStudios's Avatar
Tippy, thanks. I will look for a vacuum leak first thing in the morning.
It baffles me that the accelerator does not respond at all !!!!
Old 03-30-2009, 02:38 AM
gota911
gota911's Avatar
Does the accellerator pedal feel normal, like it still has resistance against your foot? I recall reading an accellerator pedal DIY that solved a "sticky" or sluggish engine rev response.
Old 03-30-2009, 03:26 AM
JDSStudios
JDSStudios's Avatar
Tim
The accelerator pedal feels 100% normal- just wont change
a thing on the slightly unsteady idling.
If I put it in first gear and let the cluch go slowly, I crawl forward,
if I then step on the accelerator, it will choke, jump forward, and choke again,
on and on.
Quick Reply: Aaarg!! Wierd behaviour and then Cel !!
