996 Forum 1999-2005
Custom Made
Old Mar 25, 2009 | 03:09 PM
redridge's Avatar
redridge
Default Custom Made
anyone know a place that can make something like this.... looks great and prob more safe than stands, if made properly! Thoughts?
Old Mar 25, 2009 | 03:13 PM
Van's Avatar
Van
I've seen setups like that for wheel alignments.
Old Mar 25, 2009 | 03:29 PM
ivangene's Avatar
ivangene
Parts Specialist
I can make those for you.... might be fun...
Ed
but what's the purpose of them.....
(aside from having no wheel on it... its not lifted... we could make tham taller?)
Old Mar 25, 2009 | 03:42 PM
AudiOn19s's Avatar
AudiOn19s
I think they're mainly used in car shows to show off brakes. Another reason they're soo short is because generally the other 3 wheels are still on the car when they're used.
I could see a use for a taller version though. However most of the time, I still see jack stands as "more" useful. Maybe that's because I'm always changing suspension stuff though which could not be done with this type of stand.
Old Mar 25, 2009 | 04:30 PM
gota911's Avatar
gota911
Newbies Hospitality Director
Man, I have never seen a prosthesis for a car before!
Old Mar 25, 2009 | 04:32 PM
Barry Lenoble's Avatar
Barry Lenoble
Default What's the point?
Hi,
No offense, but what is the point of that contraption? It doesn't raise the car enough for you to work on. To use it, you need to raise the car off the ground and remove all the wheels. It doesn't seem any safer than jackstands, and it will take a lot longer to use than jackstands. When the car is supported like that you can't work on the suspension either.
I would stick with a good jack and jackstands, or a good garage lift.
Barry
Old Mar 25, 2009 | 05:26 PM
C4CRNA's Avatar
C4CRNA
You could take all your tires off so they don't flatspot between drives.
Old Mar 25, 2009 | 05:33 PM
redridge's Avatar
redridge
Thats what they are.... now that I think about it, its a good way to show off some parts....
Ed:
Im just brain storming.... need to come up with a widget so I can retire. Good to know you can make custom parts...
Barry ... no offense taken
Maurice... theres cheaper widgets out there for that.
Old Mar 25, 2009 | 06:08 PM
ivangene's Avatar
ivangene
Parts Specialist
OH
in that case they are too long and you need 4 per wheel mounted at 90 degrees to eack other..... MAGA-TRAX for mud and snow ????
Old Mar 25, 2009 | 08:03 PM
racesx's Avatar
racesx
Could come in handy for rim work/polishing all 4 at once???
Old Mar 25, 2009 | 08:58 PM
steveespo's Avatar
steveespo
I'll take the Brembos
