Help with codes 409, 115 & 5525
Posted yesterday because I got an ABS, PSM & CEL lights after engine cut off under hard acceleration. I think I hit the rev limiter, which is now higher because of the softronic chip.
Car made it home but wouldn't restart 30 minutes later. Finally got the codes & hoping someone can tell me what they mean.
P1266 - code 409 - function monitoring safety fuel shut off signal implausable.
P0102 - code 115 - MAF below limit value
ABS / PMS codes - 5525 - incorrect data transfer with DME master control unit.
Cleared all the codes and car restarted but still showing ABS & PSM. Have a feeling if I drove it the CEl would be back on shortly.
Thanks for any input.
