I've got the "key stuck in the ignition" problem - but I have a question.
1 Post
Well, it happened late this afternoon. Key is stuck in the ignition. All the classic signs, according to my searches - A/C doesn't work with car turned over.
I saw all the threads on how to fix it - I just don't know when I might find the 4-5 hours to do it.
My question - does any one know if this is covered under the CPO warranty?
*Mind you the CPO warranty I have is the one prior to 8/08 - car was purchased 3/08. For purchases after 8/08 they changed it to cover a lot more items?
I'm sure I'll find out when I call the dealer tomorrow, but at least I'll know what I'm up against
Thanks!
Thanks!
just change the switch under the dash.... $30, takes 15min tops. I replaced mine at the track since I knew it was gonna die on me one day. All you need is a small electronics screw driver... 1 screw.
1 Post
Thanks - I guess the 4 hours was for the full ignition switch and lock replacement.
http://www.renntech.org/forums/index...howtopic=16077
