Durametric Software. Thank You
Durametric has great Customer Service. TY Owen S.
I bought the software almost 2 years ago for my 996 but my hard drive crashed leave me with just a $250 cable. or so I thought. One email to Durametric and a prompt response back stating I can just download the software off the site. DOH.
I''ve been scratching my head for days trying to figure out all issues I am having with my 996...
Anyways, with the Durametric hooked up I found out quickly what was causing my codes.
-ABS/PSM is a front right short in the sensor. I installed a new suspension, must have not tighten the connector well. We'll see tomorrow when I clean the connector and hook it back up. I thought it might have been my PSM module going bad or the brake switch or the speed sensor (from lowering the front).
-CEL. Bank 2 O2 sensor after Cat is throwing a code. When the car is at operating temp, I can clear the code and the CEL doesn''t come back. Just in time for smog test. Worst case I have a couple of O2 that I can swap in.
-Found my RPM is a little low.
-bunch of other nifty readings from the Durametric that I do not rmember seeing in earlier versions.
Clearing codes also resets all readiness monitors to not complete...
First thing the check at the smog test asked me when he saw code reader on floor of my car was to ask me if I had used it to clear any error codes. I told him no cause I know in doing so also resets the readiness monitors. I told him I just used it to verify all wear set to complete.
He then proceeded to hook up a small code reader that he used to query the readiness monitors to also verify enough were set to complete to continue the test. He told me any two can be incomplete.
Sincerely,
Macster.
