replace cost - ignition coils
first off, i apologize for not searching on this topic but the search functionality is disbabled for the moment due to server maintenance and I desire immediate gratification!
i started up my baby this morning after having left her for a week. she was idling rough at start and seemed like it was misfiring. i got the check engine light and "drive to workshop" message. I listen to what my car tells me so I'm driving her to the workshop. at a traffic light, she is idling rough and dies; no belching of smoke during any of this. after waiting a couple of seconds, i fire her up and smooth as silk and the check engine light goes out.
I decide to drive to work and call my mechanic; he says it may be the ignition coils and will check the codes when i drop her by.
what is the replacement cost on ignition coils and is it prudent to replace all at one time? i have a 2003 911 C2 with 35k miles. no engines problems to date.
thanks in advance.
thanks in advance.
Mechanics recommend changing them as they go--no point replacing all of them if just one is dead, the others could have 30-50k miles left. I just had one replaced and it was about $250 or so after labor.
Which was basically robbery, it's an $80 (dealer price) part and they're easy to change out yourself.
Newbies Hospitality Director
Someone else recently did this but I don't recall the cost and can't do a search. The coil packs are subjected to a lot of heat, so if one coil pack is bad, the others are probably in similar condition. If you can replace them yourself and save on teh labor cost, it would not be a bad idea to replace all of them at the same time.
They can all be replaced without removing the rear bumper.
No kiddin... they are 43 bucks at sunset. BTW once one goes bad the others are soon to follow. save yourself some grief and replace them all as a DIY. Don't remove the bumper...
I paid $60 a piece x 6 pieces when I replaced mine. Car was in for a AOS job and other stuff, mechanic suggested to replace the coil packs when he found some hairline cracks on most of them. He recommended the replacement since he was "in there already" and would not charge me extra labor for them.
As others said, about $60 a piece. There's no way you should remove the bumper or heat sheild to get these. I mean, you already remove them to do a plug change...easy as pie.
Climbing? Maybe that's the problem. I slide. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Yeah, I'll take jacking it up over pulling off body parts, but either way works.
As far as the heat shields, there's no way I could get in there without taking them off. But anyone who can use a screwdriver can take them off. Easier than filling up with gas.
