Rattling and buzzing
I've got two rattling noises that are irritating me. I did a search and found a thread on the 996 GT3 forum that was heavy on complaining and lite on solutions.
1) Driver's side door rattles -- mainly while idling at stop lights. Stops when I put my elbow against the door.
2) Shifter buzzes. Happens occasionally. Stops when I press my hand on the leather at the base of the shifter.
I can see that the PO had various rattles handled under warranty by the dealer. At this point, I would like to minimize expenditure and would love to hear about some DIY solutions. Suggestions?
I am contemplating taking the door apart, looking for loose bits, tightening them, and reassembling. I noticed that the dealer in my records used felt to deaden some noises. Any ideas on what kind of material they were using?
At some point, I know I'm going to need to do the passenger side door because it's not dropping the full distance (still drops enough) and I think I've got the "streak" issue when raising/lowering the window.
A common rattle problem (from what my mechanic told me) is that the screws that hold in the door speakers work their way out and cause door rattles. Once you remove the door panel, check that out first.
No problem. We were replacing my window regulator last summer, and when we had the door apart, I remember him commenting about a common door rattle problem that always turned out to be a speaker screw. Hope that it for you guys!
Newbies Hospitality Director
Uhmmm..... never mind!!!
