996 Forum 1999-2005
cel 1124
Old Jan 9, 2009 | 09:21 PM
tris911's Avatar
tris911
Default cel 1124
Is it correct that code P1124 has something to do with maf sensor? i'm assuming replacing the sensor is not that critical to damage the engine. advice needed. thanks.
Old Jan 9, 2009 | 10:28 PM
cdodkin's Avatar
cdodkin
1124 Oxygen Sensing Adaptation Area 1 (Cylinders 1 - 3) - Rich Threshold
As it's only one bank of cylinders showing the fault - unlikely to be MAF
MAF would effect both sides at the same time, so you'd have a fault code for bank 1-3 and 4-6 on the car.
Could be vacuum issue on the air intake, or low fuel pressure, or clogged injector
Non critical as it's emissions related - will not harm the car - may burn out the CEL bulb if you leave it lit for months and months....
Old Jan 10, 2009 | 07:37 PM
tris911's Avatar
tris911
i have a pending code 1125, probably related to banks you mentioned. thanks for your post.
Old Jan 10, 2009 | 07:47 PM
1999Porsche911's Avatar
1999Porsche911
The 1125 is the other bank (1) and indicates that you are running RICH on that bank.
