key locked in trunk - alarm on - can't find manual release
Newbies Hospitality Director
If you unlock the doors, but don't open them, they will re-lock within ~30 seconds.
So, scenario goes like this.
- car fully locked
- unlock doors on remote [unlocked]
- pop trunk on remote [open]
- put keys in trunk
- close trunk [closed]
- doors not opened within 30 seconds of remote unlock button pressed, doors re-lock [locked]
- hosed
7. hosed, you dumb f*ck!
Parts Specialist
On the contrary, we want to be open and helpful.
Here's how to break into my Porsche:
1. Remove the R front tire, gently place it to the side.
2. Carefully pull back the inner plastic fender liner.
3. Gently feel around for the trunk release.
4. Pull trunk release.
5. Carefully climb inside the trunk. Think skinny!
(you will have easy access to everything you need here).
6. Close trunk lid behind you
(that way no one can see you breaking into my car).
7. Be careful of the interior light in the trunk, it may give away your position, so make sure that trunk is closed EXTRA tight.
Voila! You have now broken into my Porsche!
I hope that was helpful to any would be criminals out there.
Happy Holidays!
LOL....I have my cable attached to a separate battery...if you are unaware it will be shocking experience. My hidden camera will also take a picture and post it on the web. Have fun ripping it off...
I had not revisited this thread since I got the car open. The comments were not so nice, but I guess I deserved it. Not sure what pics I could have sent to prove I was legit, but I can assure you it is my car. Thanks again to those who helped.
Good one man. Maybe he'd trying a prime number post record.
Life sucks some times. I should of burned a used lincoln to the ground the first day I had it cleaning the truck that night and the automatic electric trunk closer locked in the only key for it.
So with that said, here is your "Newbie Initiation!" Come on, Newbie, post the @#$%^&* pics!
Ahhhhh, I feel better!
Parts Specialist
one more thing
THANKS for posting the "I fixed it"...... thats what makes it all work!
stick around, you could learn alot (and waste a lot of time )
