AstigRacing || Ksport Coilovers
Everyone,
Before you scroll down, please read our Terms and Conditions. Astig Racing strictly and carefully screen every orders before it gets loaded up for shipping. We will always make sure that our customers will get what they paid for.
If you have any problems with the item you received, please contact me directly so that I can resolve it immediately.
I assure everyone in here that you will have nothing to worry about. Your concern is my priority.
I have Ksport Coilovers, 3 different types for the 99-04 996 Carrera/Turbo and 96-05 Boxster.
GT-Pro $1,400
Carrera/Turbo – 6kgF and 9kg R
Boxster - 5.3kgF and 9kgR
Key Features:
1. Inverted steel shock absorber for durability
2. Lower center of gravity and higher chassis rigidity
3. Designed to reduce friction for cooler shock oil temperature
4. Inverted design like vehicles in WRC and all JGTC cars
5. 36-way adjustable dampening
6. Made from high quality 6061 Aluminum with T6 for increased hardness
7. Compression/Rebound adjustable
8. Adjustable spring perch for height adjustment, Adjustable body allowing maximum suspension travel
9. Pillow Ball Top Mount w/ adjustable camber (not available for some models)
10. Monotube High Pressure Design reduces oil leakage
11. Electroplated body for protection from corrosion and rust
12. One Year Limited Warranty
Version RR $1,365
Carrera/Turbo
Boxster
Key Features:
13. Aggressive valving and spring rates
14. Reinforced internals
15. Race applications only
16. 36-way adjustable dampening
17. Made from high quality 6061 Aluminum with T6 for increased hardness
18. Compression/Rebound adjustable
19. Adjustable spring perch for height adjustment
20. Adjustable body allowing maximum suspension travel
21. Pillow ball top mount w/ adjustable camber (not available for some models)
22. Monotube High Pressure Design reduces oil leakage
23. Electroplated body for protection from corrosion and rust
24. One year limited warranty
Kontrol-Pro $1,120
Key Features:
25. 36 levels of adjustable dampening
26. Made from high quality 6061 aluminum with T6 for increased hardness
27. Compression/Rebound adjustable
28. Adjustable spring perch for height adjustment
29. Adjustable body allowing maximum suspension travel
30. Pillowball top mount with adjustable camber (not available for some models)
31. Monotube high pressure design reduces oil leakage
32. Electroplated body for protection from corrosion and rust
33. One year limited warranty
If you have any questions, please don't hesitate to contact me.
GT-Pro $1,400
Key Features:
Version RR $1,365
Carrera/Turbo
Boxster
Key Features:
Kontrol-Pro $1,120
Key Features:
John,
Your site looks nice and it's always great to have another vendor around here, and I"m sure that K-sport coilovers are good options for some cars on the market but their 996 coilovers have SEVERAL issues for our cars.
A full account of my issues can be found in this thread:
https://rennlist.com/forums/996-foru...coilovers.html
I don't mean to put down your business but I surely hope that I keep my fellow rennlisters from having the same headaches from this product that I had.
Many here are very happy with their JIC kits and Brembo products you carry.
Andy
Andy
I had no problems with my buyers under any circumstances.
You are speaking from your experience and that is understandable and it is also unfortunate you had to go through that.
