Nitrous Oxide
Parts Specialist
I ran NOS on my 'vette but would never do it to my Porsches, the chance of something going wrong is too risky for me.
Not that they cant take it, just cant imagine melting a hole through a piston or popping a head gasket. Too much work to fix.
If you had to, I would not go over a 75 hp shot. I did a lot of diagosing of a lean out problem in my 'vette with a 75 hp shot and never popped the motor, must be mild enough.
Why not a bit of PURE OXYGEN to displace 5% of our atmosphere's nitrogen, from a liquid oxygen tank at LOW pressure into the intake downstream of the MAF/IAT....??
5/30 improvement in HP/torque, 350HP rather than 300.
http://www.europeancarweb.com/tuned/...ody/index.html
.......http://www.angelfire.com/va3/ric3boi/box.html
nice propolsal but is it practical....safe...and tested?
I used to have a 1 bottle per week Nitrous Habit when I drag raced in HS and my college years. Never once had an engine failure in a vehicle that was raced almost weekly for 3 years.
A well designed system with all of the necessary safety features in place is a great alternative to SC systems for reliable HP increases with very little investment
I think the reason you don't see systems like that for Porsche's is becuase it's mainly aimed at the drag racing crowd and our cars are not ideal for that sort of racing. Most of us are using these cars at tracks with turns where the nitrous is of little use if any.
I'm sure anybody who knows their way around a modern nitrous system should be able to put together something for you. The biggest issue is going to be without being able to pull timing from the car you're going to be limited on how much HP you're going to safely be able to add to the car.
its just the prospect of loading 9k on a SC and 1-2k on install is a killing......my ? would be if a 3.4 can handle the SC which will provide higher compression etc....then with a nitrous system if managed properly and carefully can provide similar results? and might cost only 1-2 k....again i think the key is to have proper management with low "shots" and adding an intake plus headers......again just my theory,but i will be inquiring with some professional shops in this matter in the following weeks....i really hope this can work.
I have never seen the ring lands of the M96 to judge if Porsche uses thin ring lands on the pistons and rings for longer rod ratios.
If they do, this weakens the strength of the piston and makes it more risky to have a meltdown (if fuel pressure ever falls off).
On a side note, my '87 911 has very thin rings, I wouldn't think of ever spraying it even though its turboed (but many guys have had broken rings N/A, not a good sign of strength).
If you have a good fuel safety pressure switch and never tamper with the NOS jets, it should be fairly safe IMO.
But, me personally, wouldn't do it due to the complexity and time it takes to rebuild these motors.
My experience with a 75hp shot on my old 'vette was that the diagnosing stage never popped the motor even with lots of shuddering due to leaning out.
Going to 125 or 175 made the engine more violent and after I was done using it for a session, the timing was so retarded that the car lost low-end torque for a few days.
That tells me it was pulling lots of timing to prevent detonation.
Of course we are talking about V8's here, not 6's.
I have a video of my friend who drilled out a 200 hp jet (without matching fuel)and the violent explosion blowing intake parts all over the track.
I believe it quickly combusts, the reason it is added to Nitrogen to slow the burn as in NOS.
Small block Chevy in an S-10 pickup.
Plate system with progressive controller and all the bells and whistles. I also had an MSD ignition on the thing with manual timing control so I could pull timing from the ignition with a filp of a switch fron the interior of the car. At the end I was running 200hp shot on my motor on the top end of the track. It was a lowered S-10 on a 10" tire that was running deep in the 11's over 12 years ago and it was also my daily driver. Pretty quick street car for the time.
Nice!
Was it like 75-150-200 setup? Had one friend with a 275 shot on a 468 BB '69 Camaro and ran 10-teens. It was 11.2 motor alone.
Another friend had a 300 shot on a 383 SB in a '66 roadster 'vette and he ran a best 10.01. He could never crack the 9's.
These were both street cars and DD's. Neither used progressive, all right off the line.
![evilgrin](https://rennlist.com/forums/graemlins/evilgrin.gif)
Oh sorry, didn't mean to hijack
![order](https://rennlist.com/forums/graemlins/order.gif)
As I see it the ECU EFI controlled mixture ratio would not change, just putting more combustable charge inside each cylinder by displacing some of the ~70% of nitrogen in our atmosphere.
Isn't it true that in theory 100% oxygen into the intake would allow the engine cylinder displacement to be reduced by a factor of 3 or 4... and still produce equal HP...???
