Thinking X74 upgrade from ROW M030
I am contemplating the X74 kit for my 99-01 C2 Carrera, which currently has the ROW M030 suspension kit installed. The kit was Installed less than 250-miles ago. The ride is perfect; however, the car still sits a little too high for me. Will not consider an aftermarket kit so please refrain from those comments.
Any thoughts?
I may be willling to sell the ROW MO30 if anyone is interested.........Im in So. CA. and really don't want the hassle of shipping.........
Any thoughts?
If you consider than the ride is perfect, why go for a stiffer suspension?
I would go for Gemballa springs with the same shocks
As a matter of fact I'm going to lower my car with them
I think my car is too high after installling the RoW M030 too
Some pics from my mechanic Porsche specialist, and he recommends me to do that
You have my attention! These springs you indicate, are they 'matched' w/ the ROW M030 shocks or are they merely 'lowering-springs' from Gamballa? Really would like to know.......
Thank You,
http://shop.fvd.de/de/en/Porsche-0/-...%28TUV%29.html
They are lowering springs from Gemballa.
My mechanic told that M030 springs lowers 20 mm front an 10 mm rear.
These Gemballa springs lower 30 mm aprox.
If you go for these springs with stock US suspension they would forcing the stock shocks because they were too much high, but can work with Row M030
They are perfect to fit with shorter shocks (as you can see in the upper pic with yellow shock = Bilstein Sprint)
Not looking for a 'cheap' solution, just the right "PORSCHE" solution and to my knowledge, ROW M030 / X74 are the only factory choices. One, which I have is perfect - ride wise, but is not quite low enough. The other - X74 is low enough, but does have a more stiff ride, which I'm willing to deal with......
