Tranny leak?
Oct 31, 2008 | 03:39 PM
Tranny leak?
How do I check the tranny fluid level?
Oct 31, 2008 | 04:33 PM
Thats your diff, should be a plug above towards the top of the plate.
Oct 31, 2008 | 04:44 PM
I thought that the trans and the diff share the same fill plug and drain plug?
Level when you open the fill plug the fluid should be right there. IE you fill it right up via the fill plug until it starts to pour out the side.
Oct 31, 2008 | 06:03 PM
I found the drain and level plugs but couldn't get either of them loose.. I'm soo weak..
Quote:
Originally Posted by
Paul 996
