C4S Wheel Question
I need the size of the lugs that came on the stock 18" turbo twists on my 4S. Are they 17mm or 19mm? Also, what is the torque I should use for tightening up the lugs? Damn, I really am getting senile - I just realized I posted the first part of this question a couple of days ago.
Sounds like 19mm it is - and the torque to tighten? Probably asked that, too.
If you release the parking brake and put the car on level gound in nuetral, tighten the bolts till the car rolls.... its not anywhere near the right torque spec, but I thought your car might like to go for a ride.....
ALL iin fun at the pokes... I am sure you know, but thought it wouldn't hurt to say it
I bought a torque wrench from Tire Rack - it seems to be a substantial tool, and was pretty inexpensive. Around $35.
http://www.tirerack.com/accessories/...um=TW605&ID=75
Super Moderator
Newbies Hospitality Director
Wayne, I swear I was thinking the EXACT same thing when I read Phil's post.!
Phil, as the "other Tim" (Gaspasser19) stated, 95 lb. ft for the torque. Remember, if you torque them too tight, the "little green 3/4 circle light" on the dash will illuminate!
I knew I would be able to work that one in there, some how!
I will absolutely NEVER live that one down.
I know, I can see you reminding Phil of that until the day his C4S dies.
