996 Forum 1999-2005
Phone volume
Old Oct 3, 2008 | 03:10 PM
silvermilnec's Avatar
silvermilnec
Default Phone volume
Hi All
Anyone know how to increase the volume setting for the phone within the cdr220.
My parrot kit goes through the sterio but the volume is much lower than when i'm listening to music. Hence when the phone rings and cuts out the music i turn up the volume then when i hang up if i forget to turn it back down i get the fright of my life!
Cheers Chris
Old Oct 3, 2008 | 04:29 PM
himself's Avatar
himself
Originally Posted by silvermilnec
Hi All
Cheers Chris
Odd.
My Parrot has a separate volume control - not associated with the CDR220. I set the volume on my Parrot when on a call. I turn it up to the volume I want, and the next call it will start there. I can also set this through the "settings" menu on the parrot.
How is your device set up? Is the Parrot going through the AUX input? Or through the integrated phone input?
-td
Old Oct 4, 2008 | 05:52 PM
silvermilnec
Thanks for the reply, i'm sure it's going through the phone input, i only say this because i accidently came accros the Aux and it isn't turned on.
Cheers.
Chris
Old Oct 4, 2008 | 07:19 PM
Bijan's Avatar
Bijan
Had the same problem, cleared the memory (in mine by pressing both the pickup and hangup buttons for a few seconds), reconnected the bluetooth and adjusted the volume.
Old Oct 5, 2008 | 03:26 PM
silvermilnec
When i press the Parrot "phone" apears on the CDR220. Can i adjust the volume setting on the cdr220 or on the Parrot kit?
Thanks for the help
Chris
Old Oct 5, 2008 | 08:00 PM
Bijan's Avatar
Bijan
My Parrot is the CK 3000 model, volume is part of the setup menu. Check the instructions on the Parrot setup, in mine it starts with "language" then "volume" etc
Old Oct 7, 2008 | 05:04 AM
silvermilnec
Ok so i've found the volume in the Parrot kit and turned it up. No way is it on the same level as the head unit. I was told by the installer the phone input on the cdr220, can anyone confirm this?
Cheers
Chris
