Speedometer reading incorrect... Fix?
Parts Specialist
Hey all,
I have noticed the speedo is off on my 99 C2 by quite a bit (and not in the way that will help the re-sale)
I am running 285 - 30 -18's on the rear (asume thats the one with the speed control) if not 225 - 40 -18's in the front
Is there a way to fix this, and is it something I can do (some mechanical skills) or only dealer/indy
Also getting near time for tires so if I HAVE to i could change diameter tires.. but like the low profiles.
Love to get this fixed, though it keeps me below speed for the radar traps.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Ed
Ed
Hey all,
Ed
Ed
-td
![Cool](https://rennlist.com/forums/images/icons/icon6.gif)
ALL speedos from factory are "optomistic." Yes, I understand your concern about the actual miles driven (Odo meter will register an equal percentage higher). But as strange at this may seem, the error is fairly consistent all the way up. I have run many many miles comparing the digital speedo to a high quality GPS's readings. Yes, you can fiddle with the tire diameter, but do you really want to screw up the handling in order to worry about 4 mph? Porsche may have done it intentially to help keep you from running afoul of the local polizei, or to run you out of warrenty a few miles early, but basically it is no big deal.
Beside, if you are driving your car for YOUR pleasure, rather than saving it for the next guy to enjoy, what real difference does a few percent really make?
If you are concerned about it matching perfectly then change the RD of the tire you use. Increase it if you want to bring the speedo back DOWN and increase it if you want to bring it UP. In your case it sounds like you might be going, say 57, when the speedo shows 60? If that's the case move up to the next size in RD. Just understand that you will affect your gearing by doing that.....make it taller (longer).
Member - times 3
Member - times 3
I believe this 'error' is intentional on the part of Porsche.
Something to do with laws in Germany that require manufacturers not to understate speed (but my speedo said 55mph officer!) or face large fines. Therefore they play their hand cautiously and overstate the speed.
Parts Specialist
I have check the odometer too and it reads the same (long) ni other words if I have 29 on the speedo and am going 25, then in 1 hour I have traveled only 25 miles but the odometer moved 29...
some simple math says then that my car with 104k only actually has about 90k this is a "little" error that can really add up. (hense my concern about resale on high milage cars.
Personally I dont think any 996 is worth less than mine with this many miles unless it is not drivable, rebuild or has some major mechanical/body/interior issues (as mine does not)
In this case I plan to drive the wheels off the thing and get as much out of her as I can.![thumbup](https://rennlist.com/forums/graemlins/thumbup.gif)
Ed
Ed
