Taco wing adjustable?
Define what you mean by fixed vs adjustable. The factory taco wing is adjustable in 3 settings but only after you remove 2 hidden screws from the underside and make the adjustment then lock it back in place with the screws.
I mean fixed, as in there is no ability to adjust the central portion of the wing. No seams to even indicate the central section is seperate from the uprights.
Thanks,
S.
Thanks,
S.
If you your spoiler does not look like this - then it is not a factory spoiler.
